Limited Slip Diff... Please chim in
heefageLA
heefageLA
Vidalia, LA
05, 14, 17, 20, 23
Now that's a toy,lol. If you smallblock swap it,are you going with a carb or fuel injection? Any thoughts on LS swapping it,the aftermarket is huge these days for the LS swapped stuff
Yeah it will be a fuel injected LS. Either that or an inline 6 with a supercharger. The LS is the cheaper option, but I'm looking at weight really close to. I think the 6cyl might be lighter.
Edit: Now that I look I see they are just the opposite! The 6cyl is 483lbs and the aluminum LS is 430lbs...
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
I see Moe's only offers the OEM unit for my year model truck. I didnt see the Yukon on their site. Ill shoot them a PM later today and see what they say.
I wonder how these work with the traction control on the truck. Hopefully I dont have to change anything electronically so these two systems play well together.
I had the OEM unit put in my old 2013 and loved it, but could only tell I had one when I turned off traction control. Turn off traction and both wheels would burn:)
jagman_xjs
Clarksville IN
2003 2011 2019 2023
5.7 Hemi(s)
I had a Eaton installed in mine. Parts and labor were $670.
WWDiesel
1996 & 1998
5.9 Gas & 5.9 Diesel
I have installed several units in the older Dodge and Jeeps. I use the OEM Mopar type which is a Dana Spicer Chrysler 9.25 Rear Trac-Loc Limited Slip differential carrier.
Not sure if the newer ones use the same carrier....
Elkman
Monterey
V6
With 4WD vehicles a limited slip differential is adequate for most situations. With a 2WD vehicle I would spend the extra money on a locking differential which will work far better and provide far greater traction at the rear wheels.
Ram adds an outrageous $4,000 to the MSRP for 4WD but "only" $495 for its "anti-spin" rear differential and only $50 more or $545 to get the electronic-locking rear axle and these are available with 2WD or 4WD trucks.
Adding these later, as with the items included in a factory tow package, is a lot more expensive and something I learned early in my truck buying life.
RLJ10X
Southern Indiana
Jag, have you e re been to Forza in Georgetown?
It's a shame they moved.
Arkangel77
Mississippi
4.7 L
I asked the same question - I guess guys seem to lean to the OEM setup? The Yukon says its the bees knees but I have no Clue. Wish we could get more definitive advice on this
heefageLA
heefageLA
Vidalia, LA
05, 14, 17, 20, 23
If Moe's Performance refuses to sell it, you can count on it being a POS...
Ill be going with the OEM Mopar unit.
If I could install the Detroit TrueTrac without having to regear and buy a new axle shaft thats what I would do, but its just too expensive for what I need.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Unless you're heavy into off-roading/drag racing, the Mopar unit is adequate.
Lee DeTro
Prescott Valley, Az
I would suggest calling Jeff at http://www.mit4x4.com/ He's been working on 4X4's transmission's, suspensions and Diff. since the early '70's I have a 2010 RAM 1500 with 3:55 and he recommended the Eaton Detroit TrueTrac and it works great.
kurek
Northwest
I've got a selectable locker in the rear and LSD in the front of my other 4wd (along with sliders, meaningful skidplates, whole deal) - and have the Mopar LSD in my '15 Ram with the part-time transfer case.
Both trucks see plenty of use off pavement but the Ram is just too big to try to shove down serious trails, even if I armored it up like the other one it's wider, longer and worse on approach. That limits the Ram to routes where extreme demands on traction just aren't even relevant - I've never run out of traction with wheels on the ground. Between the BLD and the Mopar LSD it hooks up confidently anywhere I feel I have business driving and a couple spots where it wasn't such a good idea. :anitoof:
Not saying I would mind having more but I sure don't feel like the Mopar unit is going to let me down.
alphaprojects
