Limp mode with an Aisin
Douglas Talbot
Fairbanks Ak
6.7l H.O
  • All,
    First post here, however I have been on here doing a ton of research trying to figure out this problem. I had the infamous limp mode problem with my Ram it's a 2014 ram 3500 6.7l With the Aisin. Going through all from beginning til now. About a month ago my wife had a problem with the DEF Tank leaking and light came on and codes were thrown which I know are DEF related the P203C,204A, and U059F, then one morning she got in the truck to drive to work and she said it was hard to shift it into reverse and once she did the PRND turned yellow, and there was also a P0850 code which I know deals with the TRS and is an Engine code not a TCM code. But dealing with this limp mode I guess im trying to find another outlet on the because everything I have done up to this point has not fixed the problem. I have had the harness repaired that is behind the driver wheel well, I have also fixed the leak in the DEF tank but still have the codes showing active for that but they have not been cleared yet, so could this be causing it? I also have replaced the TRS because the harness repair didn't fix it....also the truck has 107000 miles on it. So my question is that what are somethings I can look at as well as what I have done already im currently deployed and really trying to help fix this before I get home because it is my only means of transportation and will need to drive it to work. Thanks for any advice from here.
