List some essential tools needed to start a home garage
Hawki1cr
Southeast MI
Hey all, I'm going to start working on my 2014 Ram 1500 this spring (level kit, Mufflex dodm80). I also want to start changing my own oil, rotate tires, other routine maintenance. I have one boy and another on the way. I want them to be able to do basic car Maintenance on their own so I gotta learn so I can teach them. I also need tools for maintenance on my riding mower and other household projects.
I have a three car garage so I have room for tools. I want to start collecting essential tools to complete the tasks I listed above. What do you guys consider essential tools?? Thanks for the help!
jaycabral27
Hamilton, Ontario, Canada
Two sets of 6 ton jack stands.
4 ton jack
Torque wrench 1/2" and 3/8
Breaker bar 1/2
Swivel socket and extensions
Deep impact sockets
Regular socket set
Wrench set
Vice grips
Vice
Spring compressor
Allen key socket set
Torx socket set
Various screwdrivers
Pry bar
Couple different size mallets
C clmap
Oil filter wrench
Oil pan and funnel
Cheap obd2 scanner
That should be a good enough start to get by... However if later on you want more I would look into air compressors and air tools. Lots more tools come in handy but this is a good start if you don't have any.
Sent from my SM-G900W8 using Tapatalk
sbarron
Wasilla, Alaska
safety glasses
impact gloves
flashlight
tape measure
flexible pick-up tool
telescoping magnet
telescoping mirror
Screwdriver set
gasket scraper
wire brush
hack saw
tin snips
Socket sets 12 and 6 pt metric and SAE 1/4 3/8 and 1/2" drive, extensions and swivels
combination wrenches metric and standard
flare nut wrenches
large and small crescent wrenches
allen wrenches metric/standard
Torx wrenches
filter wrench
oil drain pan
needle nose pliers
vice grips
channel locks
small pry bar
tire gauge
multimeter
code reader (if you want to get fancy)
wire cutter/stripper/crimper
dead blow hammer
ball peen hammer
punch set
drift set
file set
creeper and extra light
jack
jack stands
grease gun
an air compresser/impact wrench/die grinder/air chisel can also come in handy at times.
brake bleeding kit
cordless drill and bits
toolbox
workbench with vise
Hawki1cr
Hawki1cr
Southeast MI
Wow. Nice lists! I already got the fridge and beer. I plan to get an air compressor for air tools. What's a good size air compressor?
sbarron
Wasilla, Alaska
I do everything i need with a porter cables 6 gallon. It's handy because it's portable. Do I have to wait occasionally for the air volume to recharge? Yes, but not as often as you might think, and I'm not running a professional shop...lol If I used it a bit more than i really do, I would probably get a wheeled 20 or 30ish gallon model.
one caveat, I have a cordless impact gun (DeWalt) that seriously kicks ass, so I don't use the compressor for running an impact gun.
jaycabral27
If your going to use air compressor for air tools I would recommend something that can handle 5scfm at 90psi and 8 gallon or higher.
I use Ingersoll Rand air tools. They were good price and very good tools. Treat them right and they will last forever.
Otherwise if you wanna spend the money snap on.
Or aircat is good as well I have a few of those and they are priced well.
develand
A good general way to get a decent amount of tools is something like a Craftsman socket set. They make a lot of different count pieces for every budget. That is how I started. Knocked out a big portion of sockets and basic tools and I slowly added other stuff.
I also upgraded to a 52" Husky Tool Chest.
craigsez
Novascotia,Canada
Small fridge with beer.
OMG i cant believer you said that...
Jeeze man you need a BIG fridge for lotsa beer,ice maker for your stiff drinks and a camera with tri pod so when the wife gets a lil tipsy you can get her posen nekid on and in the truck..:favorites13:
sbarron
Wasilla, Alaska
Small fridge is ok. You DO want the friends to eventually leave. Also, lotsa beer to get your wife to pose nekid? Is that for you, or is your wife a big ol' gal? ;)
Pull Ya
Cedar Creek, Tx
It sure didn't take long for this train to fall off the track. And you forgot to put "and" between stripper and pole :naughty::naughty:
Jay
PS--Sorry OP
bcbouy
pitt meadows/100 mile house
2021 power wagon
hemi
beer fridge,air tools and stereo.everything else is secondary.:)edit: i also have the dewalt corded impact,and other than it being a little big for confined spaces,it kicks ass on stubborn nuts and bolts.
cgeorgemo
Joplin, MO
3.6 Pentastar
Ramps for when you want under the truck bur won't be taking a wheel off.
Wheel chocks because seriously who trust a parking brake anyway?
Shop manual for each of your cars/trucks.
Soldering iron or gun for wiring.
Sent from my SM-N910P using Tapatalk
RAMblin1217
Didn't see trim tools listed but maybe it was. You'll want them to remove clips so you don't break them.
Jus10case
