Lock / Unlock????
Hogfish823
2009 Dodge Ram 1500 Laramie
I was having issues with my key fob not unlocking or locking my truck. Changed the batteries, cleaned the contacts in the fob etc etc.. Followed all the self help stuff on youtube. Finally broke down and purchased a new key fob and had it programmed to my truck. Was working great for about 6 to 10 months.
Now it is not working again. I have to sit outside my truck pushing the buttons to get it to unlock or honk when I press the lock button. Once it does that I am able to unlock the truck. I have also found that if I take the valet key out and insert into the door lock and turn it just a tiny bit I can then get the key fob to unlock the door.
Any thoughts on what might be the issue?
Is there an internal module that can be tested?
RoadRamblerNJ
Mountain City, TN
392 Hemi
"Three finger salute"
Old school computer term for using
<CTRL> <ALT> <DEL> to reboot it.
Disconnect your battery for a while (30 min) then reconnect. Check you fob. Might be "fixed".
H
Hogfish823
Well, thanks. I got it fixed. SUPER technical fix......................... put the little metal piece that fell on the floor that makes contact inside the fob with the battery back into the fob after replacing the battery. Works perfect now!!! HaHa.
