Locking doors upon Exiting. Multiple "clicks"
TEC Tactical
GA
Just checking if anyone has this issue.
Upon leaving the vehicle I have to hit the door lock button a bunch of times before the door will lock.
I tested it with a meter and the switch is 100% fine. It is almost like the BCM needs to think about it or a process needs to end first before the doors lock.
MADDOG
Living in a Firepit
6.4L HEMI
That don't sound right. Mine is spot on each time I use it.
WTM75
Upstate NY
3.6 Pentastar
When I first got my truck the unlock was intermittent and a couple times would not unlock any doors. They rebooted the RF hub and it has worked fine since.
ctdodge
Bristol, CT
2017 Laramie 1500
Are you talking about the door lock on the fob or on the door handle? I've had this issue with the one on the handle, sometimes it takes 3 or 4 presses to lock the door. My wife has a 2015 Cherokee with the same pushbutton and hers works first time every time.
I had it in the dealer for something else and asked them to check it out and, of course, it was "working fine". Then they tried to teach me how to use them - "make sure your hand isn't behing the handle when you push the button". I have noticed now that it's cold it seems to be worse. But I think I have to wait until it stops working completely before I bring it in again.
TEC Tactical
TEC Tactical
GA
The door lock button on the arm rest. Sometimes it will lock on the first push , sometimes it is many before it locks.
On a second note. The steering wheel control for Cruise. Sometimes I need to hit that 5 or 6 times just to have the cruise come on too. Strange. (PS Its a 2018 with 9000 miles)
Truckit
Listowel Ontario Canada
2017 Longhorn Limited
Had the handle issue on both my 2015 and 2017 Limited. First time the dealer said it was a "lock module"? but didn't fix it. Changed the actual handle and worked 100% on both.
RamCares
n/a
n/a
Hi TEC Tactical,
We're sorry to hear about this. We suggest having your dealer look into these concerns for you. You may also send us a private message and if you would like any additional assistance while your truck is at the dealer.
Lydia
Ram Social Care Specialist
TEC Tactical
TEC Tactical
GA
Hi TEC Tactical,
Lydia
I took a video today of it and will upload the example to you tube. I need to wait untill my oil change to get it in. Third shift toys with available time during the day.
RamCares
n/a
n/a
Hi TEC Tactical,
That's understandable. We are available once that time comes around, if needed!
Lydia
Timsdually
Jersey
Cummins
My push button on the handle does that if I try to lock it immediately.
If I close the door and count to 5, then push the button it will lock no problem.
2017 Laramie.
TEC Tactical
TEC Tactical
GA
2017 Laramie.
Exactly, Like it need to clear something else out first.,
Mudders Beast
Georgia
Intermittent issue with outside door handle button, of course it would not act up when the dealer checked it.
JD RamGuy
nc
My 2019 Rebel intermittently will not allow me to lock the doors with the button on the door handle. It will function if I wait a bit ( never timed it). The FOB will work all the time. It feels like the truck is busy doing something else and ignores my action.
RamCares
n/a
n/a
Hello JD RamGuy,
We understand why this may be frustrating. We suggest having your dealer inspect this concern if you have not done so already. If you decide to go this route, we are also available via private message if you would like any additional assistance during that process.
Laura
RamCares
Octane
U S.A.
I was going to change out my screw on lock button but as I was unscrewing it I checked to see if it would still lock and it wouldnt.I screw it down a little more and it would lock intermittently.I kept screwing it down and eventually it would lock first time every time.I dont know if something inside the door was turning with the button or not but it did work after doing this.I just left the factory lock knob thingy on it instead
TEC Tactical
TEC Tactical
GA
Just an 4/20/21 update. After many visits to the dealership (s)
Still no resolution. It's still doing it and still ,"no issues found".
FlyTJ
Chicago
Same exact thing over here.
One thing I do notice is that "sometimes" on the first push of the button, I hear my tailgate lock... second or third push - all doors.
Maybe its a "feature"?!? ;-)
