Long bed to Short bed
BigMike75
I have a 2015 2500 short-bed that has been worked over pretty good by the previous owner. I have been looking for a pull off replacement for the truck, but I have only been running into a lot of long-beds. Does any one know if it’s possible to cut a long-bed down to a short-bed? Anyone know if someone has done it?
B
BigMike75
That’s a ridiculous amount of work, just get a short bed. They’re not that hard to find.
True, but the few short beds that I can find in my area are priced like gold: $2500-$3500. I can weld, and I have a buddy who owns a body shop. I can find long bed pull-offs for under $1k. I thought it might be worth the effort since the bed will need paintwork anyway.
gtomike60
Milford,Mass
5.7L HEMI
By the time you shorten the $1ooo 8' bed,you'll end up paying more than $2500-$3500
You have to shorten forward of,and behind,the wheel opening,the inner structure,and the floor.The body line a few inches from the top won't line up either
That's a lot of labor involved
How bad is the bed on your truck?
What does your body shop buddy have to say?
4th Generation Ram Truck bed measurements vary
the Bed Rails measured from the rail to rail at the front, center, & rear vary.
They are wider at the cab, then they are at the tailgate
I don't recall a 2015 Ram 2500 with a 5 foot 7 inches bed
but what do i know
Is it a Crew Cab ?
mrack
Be patient and keep watching marketplace. Any 2009-2018 1500 bed or 2010-present 2500/3500 bed will work as long as it’s the same length, but if you use a 2019+ 2500 bed you’ll need to swap the passenger side hinge on your tailgate.
