Longtube pictures
1SilverBullet2
North Dakota
2014 Big Horn 8 speed
Does anyone have a picture of where they dented their header to clear the steering shaft some or atleast a good enough one in the truck? I'd like to dent it before they get ceramic coated so I don't damage the new powder coating. Thanks!
BeanRAM
Wisconsin
What LTs are you running?
BeanRAM
Wisconsin
You shouldn't have to dent it. A lot of people don't need to.
gigabyte3
I wish i didnt have to.....have yet to do mine, its on the list of stuff to do once the weather breakes here in MI.
jwheeler
Washington
The JBAs fit just fine in mine.
Hipps2000
2013 Ram 1500 Bighorn
Hemi 5.7l
If you have to dent them then you got the wrong headers....you will also effect the flow rate of them if dented. I run ARH and they bolt right up...only thing needed to adjust was the oil dipstick...I recommend double checking your headers and part number for your truck. Good luck...
Also I had mine ceramic coated, defiantly recommend it...mine were done in silver but they can do any colors.
DILLIGAF
Canadian Forces
Canada
First off denting a header a tiny bit doesn't affect anything. specially **** ones like the JBA's.
And Yes some of us had to dent them since they dont clear the steering shaft. The other option is to unbolt the engine from the mounts and shift it but that's an even bigger PITA.
1SilverBullet2
1SilverBullet2
North Dakota
Yeah I agree^ denting them just a bit so they don't rub won't affect the flow rate if any at all. I've read and talked to enough people that I'd rather sent them now rather than later when they just got ceramic coated.
So does anyone have any pics?
Hipps2000
Hemi 5.7l
https://www.youtube.com/watch?v=azPKIjxmmdU
Proof that bashing your headers doesn't effect the flow or power output.
I guess I was wrong...I apologize...just not sure why the JBAs would need to be modified if there designed for the truck. I do believe the stainless works as well as ARH bolt right up with plenty of room around the steering column.:superhack:
Steamer170
Vancouer, BC
2012 Ram
Hipps2000 Check this link out.
https://www.youtube.com/watch?v=O1bXPNy1Yn4
1SilverBullet2
1SilverBullet2
North Dakota
Does nobody have a picture for me? I'm taking them in today and would like to dent them before hand.
DILLIGAF
Canadian Forces
Canada
here you go :) sorry for taking so long at was at work :)
1SilverBullet2
1SilverBullet2
North Dakota
Sweet! Huge thank you!
DILLIGAF
Canadian Forces
Canada
Its really just a tiny dent. 1/4 inch deep at most
1SilverBullet2
1SilverBullet2
North Dakota
I dented them just enough to have a bend in that area. We'll see how they fit on installation day
