Looking for skid plates that protect catalytic converters
turkeybird56
Central Texas
U want to use a skid plate to try and prevent theft? Hmmmmmmmm. Might be something U will have to "make" and/or have constructed. BUT beware on that, that CAT puts off tremendous heat and needs the air flow for cooling.
sullivan
sullivan
Houston, Texas
Yes, to protect from theft. I am not near my truck for a few months and wanted to come and see what you guys can suggest.
I thought it might have to be custom fabbed.
Whatever they use to cut the cats out will also cut the plate out. High temp glue a spent round on it, maybe that will deter them, but if someone wants your cat they will get your cat.
Socalramfan
Huntington Beach
2011 Big Horn
Im guessing that your truck will be outside……. Just plant a big heeping pile of Cow poo underneath the cat…that’ll discourage them :favorites37:
sullivan
sullivan
Houston, Texas
Not necessarily, it may deter them at the very least. If the skid plate is 3/16" or 1/4" its going to take some time to remove. More than likely it would be bolted to the frame vs welding.
Rlaf75
East Hartford CT
2021 Bighorn
I do remember seeing something about a "cage" that someone put around the converter as a theft deterrent but I dont remember where I saw it. I get the idea but thieves will take it if they want it regardless. I dont know where you keep the truck while you're away from it but is suggest seeing if a friend can keep it at their place and maybe drive it once in awhile to keep it moving so people think its being used on a regular basis and not stationary. Just a thought
turkeybird56
Central Texas
Yeah, I had the URL link to the cage. But right now I am on my laptop and no access to my PC url files, I will post later when on my main PC
turkeybird56
Central Texas
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
There are companies making cages for cats to prevent (read slow down) theft specifically. You might try looking for them. Its becoming big business nationwide so the prices might be reasonable. The cage mesh allows for airflow too.
Edit: I see someone already mentioned this...
TomB 1269
Schenectady NY
2019 Classic
That cable cage will only add a couple of seconds to the job of hacking out a cat. They other concern is how much "OTHER" damage do they do trying to get it out with that on if they are set on taking it.
I would strongly urge if it is an issue in your area, park in well lit locations with cameras if possible. The other option is motion detect camera system in your truck that has wireless link to let you know it detects something.
Socalramfan
Huntington Beach
2011 Big Horn
I thought about this recently as well. I'm thinking an under-vehicle motion alarm would be more useful. Yay/nay?
Have any animals that walk under your truck?
might be an unwanted wake-up call at 3am
ChloeBrooks
