losing control
justin443
Houston, TX
2010 RAM 1500 Sport 2wd
Towing the boat this past weekend i realized when i run over pot holes or a lot of rough cement doing 65+ the steering wheel is ultra sensitive and my truck swerves. how do i fix?
justin443
justin443
Houston, TX
My truck is stock other than the 2-4 drop, i hate how loose the steering feels
Birddog
West Palm Beach, FL
2016 Bright White 3500 Laramie 4X4 Long Bed
6.7 Cummins TD, 3.73
For those that have the loose steering issue, does that loose steering happen with a heavier load? I pull a single axle trailer, about 3500 lbs, and I've never felt that before.
justin443
justin443
Houston, TX
It only gets worse with heavier load
justin443
justin443
Houston, TX
what kind of pavement are you on? nice smooth pavement or backwoods crappy roads? i never had that problem with my GMC sierra so i am new to this steering.
GhostRam94
Hunstville, Texas
2009 Laramie CC
i haul a 24ft pontoon boat with a 135 merc on the back... thing is heavy as fukk.... just take it slow.... my truck swerves at the higher speeds also and i have a rear sway bar.... only thing that is gonna change it is a bigger truck or slower speeds
WhiteExpress
Midland, TX
How does the trailer sit when it's loaded? If it's not sitting level, it can pull the nose of the truck up, then the slightest of disturbance can really throw it around.
Stangshcky12
Oshkosh, WI
5.9 Cummins
How much does your boat and trailer way? Do you have a no-drop hitch or even a raised hitch reciever?
It seems to me that you have to much tongue weight which is causeing your rear to drop and your front to lift up
You really shouldnt tow any trailer over 55 mph either....
Power247
High Point, NC
6.4 HEMI
x2 See if you can find a truck stop near by that has scales (or your local landfill if you can talk them into it). Knowing your weight is the most important part of towing safely.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
slow it down when towing, with it swerving and at the speeds thats looking for disaster.
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
Sounds like you either have the towing rig set up wrong, or it's too heavy.
audio1der
Airdrie, Alberta
How is the rear end sag? Is the front end getting light, lessening the contact of the front tires??
D33k
Las Vegas
Rear sway bar, steering stabilizer and for heavy loads gooseneck, and if rear is squatting hard airlift 1000
jlb
MT
CTD
These 4th gen 1/2 tons are really washy in the back when loaded. I think it is primarily a function of the coil springs allowing the truck's weight to easily shift left to right as the truck rolls. The anti-roll bar would probably help, but don't expect any huge gains (I have one and still experience this problem). The other problem you could be experiencing is if the tongue is too light the trailer gets washy and causes sway.
If you are just towing a boat, and experiencing this problem I would be concerned. Do you only experience the problem after running over a section of particularly bumpy road? Is it possible you are new to towing and just not used to what it feels like if you are getting some trailer sway, and front to rear bounce that can happen after going over a lucky series of bumps?
Saleen5150
