Low coolant / preform service messages
Eaglefire21
Tx
Have a Low coolant warning show up coolant level is fine. I changed senser in coolant jug warning still there. Anyone have wireing/plug issuse with crewcab duallys
KoboldTaco
Los Angeles
Cummins 6.7L
Start by tracing the circuit that throws the code. Assuming you are at a proper fill level, a new sensor, Sounds like a visit with the wiring diagram, and perhaps a computer that can read live bus data, voltage etc. Not sure there will be a PID to review live but worth checking if you have access to a tool like that.
My CTD is touchy on the fill level.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
The coolant tanks have a float in them that the sensor picks up when it is full. What happens is the float becomes waterlogged and no longer floats, giving the low coolant message.
The only fix at that point is complete reservoir change since the float is integrated to the tank.
This is what I've been finding and actually when the weather breaks will be swapping out my father's reservoir in his 2018 CTD Longhorn CC Dually.
chopperman1
Peoples Republic of Massachusetts
2018 Rebel
5.7L HEMI
Try jumping the sensor plug to rule out a wiring issue. If that tests fine, then test the sensor with a magnet & meter and see if it closes. If it does, then you need to replace the tank itself. There is a floating magnet in there that closes the sensor. Here's a great video. https://www.youtube.com/watch?v=gB0-2aMFcZ0
Eaglefire21
Eaglefire21
Tx
Thank you, I will get testing done this weekend
Eaglefire21
Eaglefire21
Tx
I like that video, inforative and straight to the point
OasisNinjaBat
