Low idle
Boosted Motorsports
My truck idles low 99% of the time. No check engine lights and today finally started idling around 750/800rpm mark for a short period of time which made it much smoother. It then returned to its usual 500rpm nonsense.
It usually chooses to idle around 500rpm and causes a vibration in the cab and a shudder when letting off the brake at the light.
Anyone know how I can turn my idle up?
- Engine oil is fresh
- Air filter is clean
- Spark plugs all recently done
- No check engine light
- tranny fluid clean
I'm stumped. Any help would be appreciated.
quietpeen
2021 TRX
Hellcat
If you have warranty I would take it to the dealer....idle is controlled by the pcm. I don't remember if a tuner like superchips lets you adjust idle out not...others who know will chime in
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Yea dealership should deal with this problem, mine idles at 500 normally but no vibrations or shuttering. Hope you get it worked out.
Droid Incredible 2 on the move!!!
capebreton1967
