Low Mile 2002 Camaro Z28
Treburkulosis
Glorified Car Washer
Haslet, TX
I picked up a two owner 2002 Z28 A4 car from a 83 year old man. He had just done all of the performance upgrades and rebuilds on it, when he wife said he needed to stop hot rodding. So alas I got myself an absolute time capsule and rocket lol. It has 70k miles on it right now. I did a two step paint correction on it and then I ceramic coated it with Koch Chemie C0.02. Ill get better pictures once the coating cures in a another day or so. What do you think?
2002 Z28 A4 70k miles
Mods:
Engine:
Rebuilt LS1 with Eagle stroker kit
Ported 706 heads
Harland Sharp 1.8 roller rockers
Brian Tooley .660 Valve springs
Texas Speed Cam Torquer V2
Ported LS6 intake
Fast 102mm Throttle Body
Stock MAF for now
Volant air intake
Oil Catch Can
Engineered Cooling Products Radiator
160* T stat
Speed Engineering strut tower brace
Kooks Longtubes
Unknown y pipe
New factory muffler not sure why he went back with the stock muffler, but it will be changed soon with either a Borla or SLP Loud Mouth
Transmission:
Rebuilt A4 Reflashed
Circle D 3200 Stall
Heavy duty transmission color
Drivetrain:
Hawks Motorsports Extreme Driveshaft
Moser 12 bolt
4.11 gears
Suspension:
UMI Performance Springs
Bilstein B6 shocks
UMI tubular control arms and pan hard bar
UMI subframe connectors
175 shot of nitrous not installed yet
It needs bigger brakes
TotallyHucked
Gainesville, Ga
2017 Sport CCLWB
Very cool! Those are fun cars. Curious, what cubic inch is the stoker kit for? 388? I've got a similar cam in my squarebody, it's alotta fun over 3500
Mods:
Engine:
Ported 706 heads
Ported LS6 intake
Stock MAF for now
Volant air intake
Oil Catch Can
160* T stat
Kooks Longtubes
Unknown y pipe
Transmission:
Circle D 3200 Stall
Drivetrain:
Moser 12 bolt
4.11 gears
Suspension:
Bilstein B6 shocks
Nice find , when's it going to the track,lol.
marine0311
Ohio
I had a '02 Pontiac Firechicken with a similar set up. I learned the hard way never buy a V-6 car and convert it to a V-8. Hence forth Firechicken. Fun car to say the least. Fortunately a feller had a '01 Dodge Ram 2500 Cummins 12V wanted my car more than I did. When I finished that B-12V Cummins. I raced him, and beat his a$$ so bad even drifting across the finishline. That Cummins started a love affair with Ram trucks since.
Ynottirbo
MD
Mods:
Engine:
Ported 706 heads
Ported LS6 intake
Stock MAF for now
Volant air intake
Oil Catch Can
160* T stat
Kooks Longtubes
Unknown y pipe
Transmission:
Circle D 3200 Stall
Drivetrain:
Moser 12 bolt
4.11 gears
Suspension:
Bilstein B6 shocks
I have a 2021 Camaro SS 1LE. Have had it since new. 3700 miles. I drive my 2023 Power Wagon most of the time.
Treburkulosis
Treburkulosis
Haslet, TX
Very cool! Those are fun cars. Curious, what cubic inch is the stoker kit for? 388? I've got a similar cam in my squarebody, it's alotta fun over 3500It
408 on the stroker and yes its pretty slow unless you launch it lol. The gears do help. Its only 3200 at 90 so I can live with that.
Treburkulosis
Treburkulosis
Haslet, TX
Here is some in the garage finished photos. I will take some more when I head to the tuner in a little bit. I have new headlights on the way, a new grill, and I am going to replace the dash pad this weekend. Typical GM F body dash it cracked.
TotallyHucked
Gainesville, Ga
2017 Sport CCLWB
Yeah I'm a little under geared for it in my truck. Planning to swap the 3.90s for 4.30s later this year.
Looks great after the detail! Now it needs an altitude adjustment
Treburkulosis
Treburkulosis
Haslet, TX
Ive got a billet black grill coming until I can find a SLP one. I can't believe how expensive used Berger rear panels are... I am eventually going to run big and littles. I want bogarts, but I will probably end up with some Pro stars that I will have powder coated like I did on my last Z.
skates15
Ohio
Did it come with that pin stripe from the factory?
