LOW OIL PRESSURE
goldeneyee
Sheffield Village Ohio
2019 Bighorn/Longhorn Crew Cab
HEMI
Own a 2019 Ram Big Horn Crew Cab with the standard Hemi 5.7 engine. Today I noticed my oil pressure gauge reading appeared to be on the lowest reading hash mark at idle. I then revved the engine slightly and the pressure went up To say the + 1/4 hash mark. I did not notice any lifter noise at the low reading---everything appeared normal. Truck has 3300 miles on it and I assume break in oil. Is this normal pressure for this engine or in the alternative a bad gauge and take it to the dealer for a mechanical gauge hookup/reading.
Nick_rp
I=V/R
puyallup, wa
5.7 Sport
Oil gauge isnt very precise with needles and hash marks but idle oil psi can be as low as 5psi for normal operation which would keep the needle relatively low on the gauge.
Go to the oil psi gauge on the EVIC because it uses a numerical gauge.
RamCares
n/a
n/a
Hi goldeneyee,
If you feel your vehicle is not operating as designed and decide to have this looked into by your dealer, we would be happy to connect you with a Case Specialist to assist with that process. Feel free to send our team a private message.
Alex
Ram Cares
goldeneyee
goldeneyee
HEMI
Ram Cares: Thanks but I just love my truck and it is running just fine.....
scott lass 18
rocklin ca
2010 ram 1500
now was told by dodge mine is ok hummm 29 to 33 idle always felt very low when drive ya goes right up now too late should I worry ? use Amsoil after 1000 miles cuz oil is great have no problems noise nothing no leaks seems fine but this guy told me his vleves went 115,000 5,000 to fix sucks to here that one !
