Lower Ball Joints replaceable?
Tpearson515
Saco, Maine
Hey Guys,
I was wondering if the lower ball joints on these trucks were replaceable? I have a ripped boot in the right front so I was going to just swap it out, cannot seem to find any information online though?
2015, 4x4 1500 5.7L quad cab
Any help would be awesome
Thank you
Tpearson515
Tpearson515
Saco, Maine
BigRed4x4
Mid Michigan
Was just quoted from my shop to do lower ball joint/control arm, alignment, etc $610.00 otd.
I checked with a mechanic buddy and said that's not out of the ball park.
carnage521
Edmonton
The lower joints are replaceable. Rockauto has joints available. Simple ball joint press will push them out. I ordered the moog K500286 lower joints. They seem very solid imo.
Sent from my SM-G930W8 using Tapatalk
2010 Infantry Vet
Butler pennsylvania
I just installed a lower moog balljoint yesterday. Its easy as long as you have a good ball joint compressor/installer. Popped out in 3 minutes of turning the c clamp.
Moog problem solver lower ball joint $40 ($32 for me with military discount).
Now my stock lower balljoint was a nightnare to remove. The small nut you put a wrench on on the bottom stripped right off (nut was seized on threads from ram not using anti-seize). I had to weld a pipe to where you are suppose to use a wrench, to get it off, and use a 3 ft breaker bar on a wrench on the actual nut.
Tpearson515
Tpearson515
Saco, Maine
Thank you for all your help, I'll be replacing this soon!
Ram Night
Southwest, Michigan
I replaced both of my lower arms with moog that I purchased from Rock Auto. I got the ones with the greasable ball joints. This way I had new bushings also.
2010 Infantry Vet
Butler pennsylvania
Removing the factory lower balljoint is easy as long as you grind off the material around the top of the balljoint. It will help the ball joint press down easy without it. The new balljoint will have a circlip that you install to keep it from dropping down.
Tpearson515
Tpearson515
Saco, Maine
That sounds like a good time... Haha, hopefully when I do mine I wont run into this,
joshhhh
