Lower notch
Max1329
5.7 Magnum hemi
How's it going everyone, so I was just given a Max Trac 3,5 lowering kit for my ram and being that this will be my first truck to lower I have a few questions, will I need to notch my frame or bed and or remove wheel liners I am currently running 20" rims and don't plan on going any bigger
ST-8
It will probably take big bumps like **** if you keep bumpstops in rear but it’s not necessary for a notch at 5” tho your all of maxed out on how low you can go
Max1329
Max1329
5.7 Magnum hemi
Would you suggest removing bump stops?
Silver Bullet
DC Area
V10 8.3L
If you remove the bump stop it will provide a little more travel if you need it. or your could run shorter bump stops
