Andler2008
I had tried, and failed at installing a set for 2.5" coils spacers to level out the stance of my truck. I got to the point of taking of the lower shock bolts, and put an air drill on both sides (of course both spinning in the same direction) and they wouldn't come off. loads on PB Blaster and lots-o-heat and nothing. So Has anyone had this issue and how did you end up getting the bolts off? Obviously they will need replaced, just cant get em out to do the replacing part.
then maybe I can use my BFH to press it out. Oh or maybe use a balljoint press. OHHHHHHHH that may work if I can get the head off.
