lowering question
RAMSPORT2012
Good day ladies and gents,
i have a 2012 ram 1500 crew cab 4x4 mini box, im picking up the ground force 9984 with the spohn panhard but i do have the hellwig rear sway bar on ym current rig. Will this cause issues or anything i have to do to prevent future headaches
thank you
charonblk07
Calgary, Ab
F1-A forged 349ci
There's no interference issues with the Hellwig bar and the Spohn panhard bar. Your swaybar endlinks will be too long and the bar will not be level so I would recommend picking up a set of the adjustable endlinks when you can just to get it back to the proper alignment, it's not the end of the world if you don't do it right away.
R
RAMSPORT2012
what kind of adjustable end links would work??
R
RAMSPORT2012
hellwig 8-11" is what ive been reading part # 7961, sound right???
thank you for the info and feedback
R/T_Fire
Pleasant Grove
No issues at all, I'm a little lower than 2/4 and have the 8-11" units on mine and I can't go any lower with them but still no issues at all.
Here is my set up... everything in red so its easy to see :roflsquared:
Raadz
