Lowering rear 2 inches
gto64gto
Tbor City NC
I have a 2017 ram night crew cab 4 wheel drive that's stock with 20 inch rims. I have been reading post about lowering rear 2 inches to level the looks. I don't mind cutting springs as I've done this many times on different vehicles with no problems. I have 2 questions. 1-if any one has cut springs to lower rear, how much did you cut to lower rear 2 inches? 2-I have read here that if you lower rear, it will move the rear tires forward. For the life of me, how as I haven't ever had this problem . How does this happen? Also a 3rd question, How large dia. front and rear sway bars can I install on my truck and still use stock mounting holes and who makes them? Thanks so much for your help and time.
KCaudill
The RAM
Blacksburg, Va
GF makes a rear lowering spring. Im thinking of going that route over cutting springs. I would suggest helper bags also for when you have a load to combat squatting.
If you don't mind a little fab work on the brackets you can put the 3/4 ton rear swaybar on,if that's not up your alley Hellwig makes pretty decent swaybars for both the front and rear of the 2 wheel drive trucks,if you have a 4X4 your SOL on an aftermarket front swaybar,but you can still use Hellwigs or the 3/4 ton swaybar on the rear.FYI the stock swaybars are hollow bars,they're not a solid bar. Usually cutting the springs is a trial and error method,probably start with about 3/4 of a coil and go from there. The rear tires move forward because the rear locating arms go from semi parallel with the ground to an uphill direction,which in a nutshell means the locating arms basically get shorter.On a 2" drop they won't move forward enough to really be noticeable.If you encounter a high speed sway after lowering,you'll want to look into either Illicits or Inez's rear relocation kits,which bring the rear locating arms back down and into factory spec.
DoubleB223
Ky
2017 QC
I put the McGaughy's 2" Rear Leveling Coil Springs on my 2010 Ram 1500 QC and they were perfect. I have a 2017 now and Im looking to do the same.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Used a GF 2" in rear on my 2011, me and a buddy had them on in 45 minutes.
