LSD or Not?
BIT1 BIT
Charleston, SC
Hi guys, I have a quick question. I have a 2014 1500 and am hopeful someone here could set me straight. I'm trying to find out if my truck has a LSD or not. I've been to two different dealers and one said I do and the other said I don't. The code on the rear axle says P68214856AA 3.21. The build sheet says 3.21 Rear Axle Ratio. I'm wanting to change the fluids but am not sure if I need to put slip additive in along with the gear oil (which do you recommend?). Thanks in advance for any insight you offer!
zogg
Southern Illinois
2018 Ram Express Quad Cab
Nope...you have the same as mine....wish I did have LSD
BigRed4x4
Mid Michigan
"The code on the rear axle says P68214856AA 3.21. The build sheet says 3.21 Rear Axle Ratio."
yillbs
No LSD for you.
1500canoe
Central Pennsylvania
I passed up buying some nicely equipped vehicles recently just because they didn't have LSD. I can't see a reason not to get it, but with that said, it's not like it's a huge deal without it.
BigRed4x4
Mid Michigan
What were the price differences between those trucks with and without LSD? Definitely something I am going to look for on my next truck.
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
I saw this and was like..., uhh no, dont do that kinda serious drug...lol
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
It won't hurt anything if you put the additive in.
I use fords versions of it cuz it is 2x as much for 1/2 the price in my cherokee rear axles. They have lockers, not LSD.
The additive cuts down on the noise.
Mineralram
I have had trucks with lsd and without and purposely but my 2017 without and have never been in a situation where I needed it either
TRCM
USN, Retired
Newport News, VA
With today's braking & traction control systems, generally you don't.
huntergreen
Marine Corps Navy Badge
With 4 wheel auto, and the Brae traction control, it is easy to do with out LSD.
ColdCase
The need for LSD is not as significant as is was before traction control, but it does work smoother, quicker, and without as much power drag. So there are situations where it performs much better, but you can get by without it.
gregs2018ram
Tennessee
Actually its called "Anti–Spin Differential Rear Axle", and yes its $435.
Looks like mine has it, and didn't even realize. Knew i had the 3.92 axle.
Paul84043
Lehi, utah
V6 ecodiesel
LSD's are a very specific niche option and as has already been said.. the brake LSD, simply applying brake to the tire that's spinning, works wonderfully in the real world. In Grandpa's day, he'd just tap the brake to accomplish the same thing..
If you want to get serious, put in an Eaton Tru Track and call it a day. Best LSD made, it's a Torsen style Diff, all gears, no clutch packs. I ran one in my Jeep and they are absolutely bulletproof and for $700 ish you can't go wrong.
Nothing wrong with building in a little bit of invisible insurance.
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Amen. I run 4.56 front and rear gears and when I regeared from 3.55 I put in the Eaton TT LSD. Completely different truck now. Beastmode.
You're not putting a Detriot Tru Trac in a ZF diff for 700'ish,it's closer to 1500'ish just for parts.You need to swap your ring/pinion to the earlier AAM 9.25" ring/pinion and buy one extra drivers side axle,plus a master install kit,then you have to add labour on top of that.They are good though,after blowing up the OEM limited slip in mine a couple times,and the dealer telling me they might have a tough time pushing a 3rd one through,i bit the bullet and put a Tru Trac in my 2014's ZF diff.
Spirit79
6.4 HEMI
I have LSD on my 2015 2500 6.4. The dragons flying around on the hood was a distraction but otherwise a good option.
Reticle918
