those answers are close and certainly entertaining, but it has to do with a somewhat obscure Physics Law. There is a force on a spinning axle, whose direction is determined by the Right Hand Rule. If you use the fingers of your right hand to curl in the direction of rotation of a spinning shaft, the direction of the right thumb will show the axial thrust force. So the lug nuts on the right side of a vehicle, when the vehicle is moving forward, have an axial force toward the center of the car (tightening, if you will), whereas the lug nuts on the left side of the car experience an axial force away from the center of the car (loosening, if you will). In real life, the axial forces are relatively small in relation to the clamping forces of properly torqued lugnuts. So Chryslers were over engineered until the early 70's.
