MAF Question on 2013 Ram 1500
ColeCardelli
Georgia
Hey ya'll, I have the Edge Insight CTS3 installed in my cab and I was messing around with some PID values and came across the MAF PID and was wondering what a normal reading would be at idle and driving. At idle right now i get about 5 g/s and when I'm driving at normal speeds it jumps around from 40-120 g/s and I've even seen it jump to 240 g/s. I do have a cold air intake and muffler delete. Just wondering if my values are normal. Thanks.
The g/s reading is dependent on how much throttle the engine is getting, the reading should be fairly stable when cruising at a steady speed/rpm while on flat pavement with no wind. The more load the engine is under the higher that number will go, you may see higher than some having a less restrictive intake/exhaust.
