brian hood
Hello everyone! Im new to the forum and need a little help. Ive got a 1985 D100 with a great body on it and no power train. It was a slant 6 with an automatic truck from the factory. I do have a good running 2002 360 and a 5 Spd NV3500 from a low milage wrecked 1500. I have a manifold that will convert it into a carb set up ( I know injected is probably better but im not very good with wires and I didn't want to take on more than I can handle). My questions are as follows. What motor mounts will I need? Will I be able to use an older electronic ignition or should I buy a Petronix type set up? Is there any sort of conversion that I can buy that will convert the electronic speed sensor into an older style odometer so I can have a working MPH gauge? Can I use the flywheel that came with the truck or will I need a special FLYWHEEL? I got the pedal assembly from the 2002, will it be difficult to fab it into the !985 dash assembly? Should I use the accelerator linkage from the 2002 or would I be better off using the old 1985 assembly? The brake master cylinder seemed a bit larger on the 2002 than on my 1985. Since it is matched to the 2002 pedal assembly should I use the 2002 booster and cylinder? Any help or suggestions would be appreciated.
Brian
Brian
