Malthael
- Joined
- Jun 22, 2026
- Posts
- 12
- Reaction score
- 6
- Location
- Michigan
- Ram Year
- 2000
- Engine
- Magnum 8.0L V10
So I am putting together my 5.7 2009+ when I measured the crank journals the mains were at the smallest allowable tolerance. Now I was installing ARP main studs so I had the block align honed and bought standard bearings, now since I didn't have a dial bore gauge I used plastigauge which showed .001 of clearence on all the mains. This has me concerned the crank still rotates freely, but I'm going to have around 11.3:1 compression so 0.8 higher than factory and plan on shifting at 6000 rpm maybe 5900 rpm, with a BTR stage 2 cam, was wondering if getting different main bearings would be the smart move here? Like -.001 undersize(oversized for more clearance) to increase my clearence to .002. my main concern is spinning a main bearing the first time I hit 6000rpm I am thinking of buying these bearings CLE-MS2220HX to increase my oil clearence.
