Just thought I'd update the forum with a set of 6x9's that fit the front doors. 2 mounting holes line up and 2 don't. I suppose I could've drilled 2 new holes but the two I mounted hold the speaker tight enough. The depth is fine as well as the face. They sound great and were only $46 on ebay. Here are the features:
6" x 9" DX Series 3-Way Car Speakers
Power Handling:
Peak: 240 watts per pair / 120 watts each
RMS: 120 watts per pair / 60 watts each
Laminate Paper cone material
Pressed Foam speaker surround
Smooth 13mm Hard Dome tweeter
Articulate 2.5" mid-range tweeter
CEA-2031 compliant speakers
High-temperature 1" ASV voice coils
Polyester Fiber Cloth suspension spider
High Flux Y30 Ferrite magnet motor structure
Integrated crossover with 6dB high pass capacitor
Heavy gauge stamped Steel baskets
Two piece custom paintable grills
Perfect OEM replacement speakers
Shallow fitment for today’s vehicles
4 ohms impedance
Frequency response: 60-20,000 Hz
Top-mount depth: 2-7/8"
Sensitivity: 93.6dB
Power Handling:
4 ohms impedance
Sensitivity: 93.6dB
