Time for some trailer math.
First, go here and download the 2020 Ram Towing Chart. It has some critical info you will need.
https://s3.amazonaws.com/chryslerme..._HD_TowingChart931nt9qmsd8aerespefd6bsda4.pdf
Find your truck on the chart
Then you need to know the following:
1. Truck "base" weight aka dry weight or curb weight. That is found on the linked document.
2. Truck Gross Vehicle Weight Rating (GVWR). That is also found on the linked document.
3. Cargo weight. How much weight will you be putting in the truck such as passengers, gear, accessories, hitch, tool boxes, etc...
4. Trailer GVWR. This is how the trailer weighs fully loaded. Most folks use the GVWR number even though they may not fully load it to the max rating. You can cheat this down a little, and the trailer pin weight, by weighing your trailer after you have loaded it.
5. Trailer pin weight (fifth wheels) or tongue weight (TT). Add that to cargo weight. Pin weight of a fifth wheel is somewhere between 15% to 20% of the trailer's weight.
5. Truck Gross Combined Vehicle Weight Rating (GCVWR). This is the maximum amount your truck and trailer combined, loaded, can weigh.
Now with all those numbers, add the base weight, cargo weight, trailer pin weight. Compare that number to the truck's GVWR.
Next, add your truck's weight to the weight of the trailer. This is the Gross Combined Vehicle Weight. Compare the sum of that calculation with the GCVWR shown on the linked document. If you have calculated all your weights correctly and your truck + trailer GCVW are under the GCVWR then you are good to go.
Remember, your axles have weight ratings so it is always good practice to go to a truck stop and get the loaded weight at each axle including your trailer axles.
