McGaughys 2/2 spring set installed.
stretch78681
Texas Hill Country
2018 BIGHORN
5.7 squirrel cage
Called Switch Suspension they hooked me up with 2/2 spring kit. Before you jump on me, let me say "I wanted to keep the rake". I like the look, when I hook my trailer it won't squat. Put $55 deposit down rented spring tool was done in 4 hours. I love air tools, too! Had to pay extra for the alignment "Because the suspension was modified". Going to drive it a couple hundred miles first, but think I may change out the shocks too.
cbo
Truck looks giid man. How much were the springs?
stretch78681
stretch78681
Texas Hill Country
2018 BIGHORN
5.7 squirrel cage
how much was it to rent the spring compressors? Do you really need it or can you go about with out?
Compressor was $55 deposit. My goal was to not completely disassemble the suspension. I did completely remove the front shocks, only removed bottom bolts of rear shocks. You could probably do the job without a spring tool, but you might need a "A arm fork", and front suspension parts.
