McGaughy's deluxe 2/4 drop installed...questions answered
Swampmoose
Just installed the 2/4 drop spindle kit this week and wanted to answer some of the questions I had before I ordered it for anyone out there thinking about doing it. I searched for days trying to find info before I ordered mine...
First off the kit is very well made and i didn't have to modify any of the parts to install it. My main concern was that I was going to have to grind the spindles like mentioned in a few threads... I'm pretty sure that only applies to 2013's as mine had plenty of room and doesn't rub at all. Not saying that applies to every 2012 and older, but there was plenty of room on mine and on the 07 I installed for a buddy this week.
Another concern I had was the front wheels sticking out... Yes, it does widen the front track a little(mine less than a 1/2" on each side), but I would have to point it out to 9 out of 10 people for them to even notice it.
Special tools required... a 3lb sledge, a set of large wrenches or sockets(18mm to 27mm was the set I got), and a grinder/cutting wheel.
The ball joints on mine were not hard at all. Two love taps with the sledge and they fell right out. The instructions say to cut the bottom ball joint stud even with the nut when you install the new spindle... I didn't do that because if I go to sell or trade it in I will most likely put it back to stock. It still has plenty of clearance and if you go to remove it and if the ball joint spins you have nothing to grab ahold of to double wrench it and get the nut off(which I had to do on all 4)
It also says to grind the cups for the stock bump stops flush... didn't do that either. The supplied bump stops line up with the cups and again, I'll be going back to stock eventually. I'm sure there's a good reason(liability) the instructions say to do these things... as someone probably tried to jump a hill and trashed their wheel or rear end, but I don't plan on doing that so I think i'll be fine.
My truck drove great right after it was done, no pulling or wobble at highway speeds. The steering wheel was off a little to the left when going straight and I took it the next morning to get aligned which corrected that and any camber issues caused by the drop.
Sorry for the long post, just trying to answser some of the questions I had when trying to choose a kit myself. Feel free to ask any other questions or if you're in the Tucson/Phoenix area hit me up and I'll be glad to help with a install! Pics coming soon!
chrisb38002
Lakeland, TN
Great Information.
I had the McGaughy kit on my 03. The reason they say to grind the lower ball joint stud is if you have 17" wheels (like I did), the wheel will hit the stud with the 2" drop. If you have larger wheeels, it's not an issue.
Not sure why the say to grind the bunp stop cups, I didn't have any issues with those either.
BlkRamRt
SoCal
HEMI 5.7
for my belltech 2/4 drop they didnt cut the front bump stop cup off and whenever i hit a bump or pothole i hear the metal on metal hitting each other.
TylerB
FL
You can get away without messing with bump stop cups on a spindle drop because you're just moving the wheel center up 2", on the coil drop you're moving the whole lower A arm closer to the bump stop cup therefore you need to cut.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Great post. A lot of useful info in here.
BlkRamRt
SoCal
HEMI 5.7
i just learned something....good to know this info.
Crashno1
South Florida
2014 R/T
