Mevotech UCAs
rtm03862iq
NJ
Hello,
Getting ready to install my Mevotech UCAs; however which one (part number wise) is for the driver side and which one is for the passenger side? What's considered "right" and "left" on the truck?
Padilen
Passenger side is right driver's side left. As for part numbers I don't know but I'm sure it's easy to check on.
SwollenMonkey16
They don't specify which goes where even with the different part numbers buy once you take the oems off you'll know which goes where due to the angles
sriley531
Ohio
I had the part numbers for which was which jotted down when I did mine, I'll see if I can find the post here that had them. That said, the very best thing you can do is when you pull your front wheels, just pick up the mevo's and visually match them up to the factory arms. The contour will be obvious right away as to which one matches which side. Then lay them in that side of the truck and go about your business.
Another tip in case you haven't heard it, give the mevo's a few good coats of paint. The paint out of the box is garbage and I'm sure they'll just very quickly without a better coating
phrater
Renton, WA
2014 1500 Express crew cab
Hello,
honestly, if you need to ask what side of a vehicle is left & right, you shouldn't be turning wrenches on it... I'm not trying to be an ass, but i'm just saying...
rtm03862iq
rtm03862iq
NJ
Figured out the UCA orientation. Thanks for the replies.
Coming along. Almost done
