Missing Jack and tools
Smitty2495
Accident Maryland
3B79E6B9-7A35-4333-80AA-616B7E9DCD03.jpeg E7C7A87C-8788-4B7F-BC9A-4E40E481527A.jpeg Since both 1500/2500 have jacks in the same place I figured I’d post this for all 5th Gen folks.
Geeking out over new 2500 I was sitting in truck looking at the manual and cool features when I thought, “hey where are the jack and tools located?”.
I found the passenger seat cover and removed it to find 4 broken tabs and no jack or tools and 4 strips of yellow factory tape wrap sitting under the seat.
Im not suggesting a factory trend or anything. But everyone may want to check. I’m curious if anyone is missing anything. It has the tail gate wire secure piece, and a hitch sleeve. I hope I’m not missing anything else.
Likely taken by someone at the dealer or transport, distribution yard or something. The truck was freshly unloaded and I bought it with 8.2 miles on it. I drove it home 3 hours and it’s sat secured.
Dealer is tiny with 2 salesman, a secretary and 7 mechanics.
Salesman felt awful ordered a set and will send it.
Disappointing and odd.
(What I saw)
yakalong
KC
Interesting, I think I better check mine. thanks for the info
papac0rn
Wolcottville
Thanks. I haven't even tried removing the cover.
Sent from my SM-T830 using Tapatalk
whetrick1
And make sure it has the gas funnel too lol.
chri5k
USA
Diesel
Maybe the tabs broke during shipping and the helpful dealer prep folks removed the tools so they wouldn't rattle during the test drive.
whetrick1
Yes if you have the one without the gas cap it sends a funnel with it so you can put gas in it with a gas can if need be. 28d44b08affda283bcb80cda08566eeb.jpg
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
I didn't get a funnel :mad3:
Where was it located in the truck when you took delivery?
Elkman
Monterey
V6
This is something that is usually added by the "detail and prep" guy and can be overlooked. They also add fluids so I check for the jack and also check fluid levels (coolant, ATF, etc.) before taking possession of a vehicle.
whetrick1
It's was attached to the bag that the jack handle and rods are in. Under the passengers seat.
turkeybird56
Central Texas
smity: YUP, someone removed them tools. Since U bought a 2019, may have been on the lot a while and my opinion is someone else needed tools and the cannibalized yer ride, just IMHO...
Assuming U have the same as a 5.7 setup:
After U run yer truck a couple hundred miles, check Overflow coolant bottle WHEN cold. FCA got a bad habit of quite literally only having the bare minimum in there. I had to add some to my truck, so I went to dealer and bought full concentrate and split with demineralized water and have now less usage 2 gallons of 50/50. Just saying...
Crazyro
SC
Mine was missing as well and didn't notice until a few days after I bought the truck. I ended up just buying a 3 ton jack w/ stand built-in and keep it behind rear seats. Much better than factory anyway. :D
Randy Ross
Deal Island, MD
Cummins
View attachment 192500 View attachment 192501 Since both 1500/2500 have jacks in the same place I figured I’d post this for all 5th Gen folks.
(What I saw)
If you think that's bad, I ordered my truck online from a big dealer in Greenville, SC and had it shipped to my home in MD. It was missing the spare tire, both hooks on the front were chipped and rusted where the paint was missing, no fuel in it and the cargo box lid cover on the drivers side of the bed was coming off Had to fight tooth and nail with them to get the tire and new hooks. I took it to a local dealer to get the lid cover fixed. They "fixed" it several times and it still came loose. They even ordered a new lid and cover. It still came halfway off. It's held on by several double sided adhesive tape. I took t to their body shop and they glued it back on. It still came loose. I asked them what do they use when they replace body panels. The Manager said they use an industrial strength glue. I told him to glue it all over the underneath side of the panel. So far it's held up. I live down by the shore and with it being black, it absorbs the intense heat we get in the summer time. The lid cover is plastic and has to be painted to match the truck.
When you pay close to 70K for a 2500 diesel Laramie Limited, there's no reason for it to be shipped with these defects.
It's a 2500 Laramie Limited.Cargo Box Cover.jpg Cargo Box Cover.jpg 56329625852__B40CF324-B000-4FB8-9FF7-50138CD5AA81.JPG 56329626809__73FF4B84-B85C-4CD8-99F4-F65068B85203.JPG
Smitty2495
Smitty2495
Accident Maryland
Turkeybird
Thanks for the tip!!!
It was on the lot 2 weeks which is obviously enough time to pirate. It’s a recent Night package that arrived via carrier 12/16/19 with 11/2/19 build date.
whetrick1
That's what I like to do is stir the pot a little bit every now and then lol
kbrown
5.7L HEMI
Checked mine. All there
Sent from my SM-N950U using Tapatalk
Lowrider357
