Morimoto headlight harness issue
chrisp2493
Always Modding
Warren, OH
392 Hemi
For people that have done a Morimoto projector or HID Retrofit, has anyone had an issue with the high and low beams being reversed? I’ve seen 3 different harnesses that we’re backwards now, I’ve had to switch the high and low beam pins on the Morimoto connector to fix it. Both on 03 trucks if that makes a difference.
I Bleed Ram Trucks
Nick@GotExhaust
Supporting Vendor
SC
I have had it happen to me as well. Just swapped pins on the plug and it worked. Pretty sure it was when I built the headlights for my mustang it was like that
Shadow Ram
Houston
5.9L 24V Cummins
So I’ve been battling the same issue, but still unsuccessful. One way beams are reversed per the dash indicator for high beams. Another way the high beam indicator goes between bright and dim. Last way no lights at all. Therefore, I went back to beams being reversed because at least they work. Any suggestions?
BoBoway4
