Morimoto hybrid xd turn signal not working
rroche1982
Baton Rouge
EcoDiesel
I installed the morimoto xb hybrid lights, I have a 2013 2500, the turn signals do not work, and suggestions on how to fix it?
Dinky
Oregon
Alfaobd. They are probably led you need to change the settings
Administrator
turn the ignition on but don't start the engine, check the turn signals. If they don't work use a volt meter to check for power at the socket.
R
rroche1982
Baton Rouge
EcoDiesel
So they were working with the old lights. When I plugged the new ones in the don't flash at all. Truck says both front turn signals are out
R
rroche1982
Baton Rouge
EcoDiesel
I haven't done this. They old lights were stock quads, which were not led.
I thought the morimotos we're plug and play
Administrator
I noted about checking the turn signals with the ignition on but the engine not running for a reason, it should bypass the BCM from turning the lights off.
Did you try flipping the plug over into the new headlights?
R
rroche1982
Baton Rouge
EcoDiesel
Just tried it, no go. Just says turn signals out
Dinky
Oregon
If I would try alfaobd. I had issues with my 4th gen and alfaobd fixed it all.
HKkid
Missouri
Don't have any experience with them, but the website says may require reprogramming. May start there.
hunterdan
SE PA
2019 classic
The hybrids use the stock turn signals and sockets. So, there's no reason they shouldn't work unless you don't have them plugged in, especially if you're using the stock bulbs.
R
rroche1982
Baton Rouge
EcoDiesel
Man I finally got it to work. All I did was change the setting in the truck to led turn signals and they started working fine. Crazy
sickjoepick
New Braunfels, TX
I had the same problem. determined the solution was to install 3157 turn signal bulbs. the sockets were empty from the factory. No OBD needed.
