Morimoto mini's vs retrosolutions H13 full projector kit
ljvsnyder
s. Illinois
JJ,
I was on Retro Solutions web page and noticed that in addition to the Morimoto's they have a full retro kit for the h13 headlights. Is one better than the other? Which would be the easiest to install, if I decided to try it myself? And can you get both items? Only see the mini's on your website.
TheMaddog
DFW
morimoto, is hands down the best projector, imho. that's why jj uses it
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
When it comes to projectors there are a LOT of different ones out there, ranging from cheap ****, to cheaper ****, to good, midline and just flat ******* awesome.
The ones Todd sells (the H13 ones) are the "G3" projectors. They are a good projector, tagged with some great HIDs. :D Performance wise........not as good as the Morimotos.
Price wise, I believe the Morimotos are a little higher, but the few bucks is well worth it in this case.
ljvsnyder
ljvsnyder
s. Illinois
is there any housing modifications needed to the RAM duals for the morimoto's to fit? Really want to upgrade the lights, but budget is tight on mods right now. I could probably swing the DIY kit, but not much more. Any photos out there showing the difference between drop in HID vs full retro with HID?
WhiteExpress
Midland, TX
You will here a lot of opinions on this. Truthfully, the Ram housings are not designed for an HID bulb. That being said, the light pattern from the Gen IV housings isn't terrible wtih HIDs in them.
With THAT said, the light pattern (both on the road, and the glare for other drivers) is greatly improved with a projector housing. I am personally running a Morimoto D2S projector housing (to work with previously purchased components) and I absolutely love them. The light is almost perfectly smooth (only a tiny 'warm' spot) and the cut off is crisp and delightful.
This bit about Morimoto's being the BEST projectors is far from the truth. But they are a darned good one, in the retrofit world, they are considered a cheap viable alternative. Their main benefit is installation ease.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Bang for your buck, they are VERY hard to beat. :naughty:
Yeah, there is always something better out. Heck, I have a set of TL projectors and a set of FXR v3 sitting at home right now. The TLs are about the size of a softball, no way they would fit (nicely) in our lights. LOTS of hacking on those.
The FXRs, I think with some ingenuity would fit in the quads.........but it would be a lot of fabbing too.
Its really hard to beat the Morimoto H1 projectors. With the 5th revision of them (current ones), they have addressed a few small concerns from buyers, making them even better. :D I recently saw a few pics of the MH1 vs a LS460......and for the difference in parts costs (approx 150 bucks) and labor ($$) - well, its not like these were cheap to start with. :Grenade:
Here's a thread I just popped up about the differences in the 3 common setups we see on our trucks - stock, drop in HID and projectors. http://www.ramforum.com/f96/stock-vs-drop-hids-vs-projectors-19497/
Arturo Rojas
