Morimoto vertical fog is coming
mpress2570
2010 infantry vet gave this thread cancer.
Beast_TX
These days on forums I don't even know what sarcasm is any more LMAO!
St3althM0de
St3althM0de
2016 1500 Express black out
5.7Hemi
Can you guys take 3 pictures for me? Front of truck from about hood height with both lights in view, driver fog and passenger fog straight on from a few feet back? All with no lights on please.
My passenger side fog is perfectly center in the frame, but my driver side fog, the rim of the light housing tucks inward towards the bumper. But the tabs and everything line up on the mounting holes? Could just be me, but it’s annoying me now.
Pa.hemi.ram
Pittsburgh
Hemi 5.7, 6" Rough Co lift, Fuel wheels, Bully Dog Gt, K&N CAI, Magnaflow Exhaust
They done seat very well St3alth. Not impressed with the mounting and fitment at all. They are bright though...
JB1
Houston, Texas
I haven’t installed mine yet but I’ll let ya know how mine fit this weekend
mpress2570
You sure you have the housings in the assembly correctly? If it’s not that could cause what you’re talking about.
mpress2570
I don’t see how. What year is your ram? Mines a 17 and they’re flawless. 712ac7e4028c787499127f20cb35751e.jpgce5987b8b3908478a6ad9c7a9f7cfefa.jpg2dc626ec2695db522781a4d8a8a4dda9.jpg
pgr1990
Mines an 18 and they fit absolutely perfect on mine as well
Maligator
Hem 5.7
I have a 17 and I have gaps of at least 1/4" to 3/8" between the housing and the bumper on mine at the bottoms
mpress2570
That’s weird. I’d double check everything you did. The first time I installed the assembly I did it wrong and the housings pointed up so high they matched the height of the headlights
mpress2570
If everyone is expecting these things to sit flush up against the bumper cover they are NOT. They are made larger than the opening to protect the contents behind the fog lights. Like the wiring and headlights and engine components. If you noticed the stock housings were much larger than the opening. They are also not meant to sit close or sit flush because it would wear out both the bumper cover and the housings if they were rubbing up against each other. They are supposed to have some gap between them. That being said. Here’s how they should look. If yours look like this you have nothing to worry about. 1f8f7abbcf24576b5bab92c5fffb4229.jpgaa29c3ac91d81e2ed5b08218d2c56d2d.jpg03473072aa8c5a29dccca6a04a0b0177.jpg83c95b73226dee374b1d80b818e7cdc1.jpgc1c231a294e980ead76ff7901b73b258.jpga9e7c44b1abd5c5085e5cded7d9f9038.jpgd7b96cff2e70010ab43395db96fb5eb6.jpgcf985ee505e68a0cb3adad1376b4ffa6.jpg
mpress2570
Here’s an example of how the stock housings fit in the truck. The stock housings have a larger gap at the bottom than at the top. 3e5c7f4fcf4d72feba7297144d544801.jpg
jasonw
South Dakota
3.0L Hurricane HO
I did that as well on my first light. Installing the second, I discovered my mistake, and fixed the first one. All good now, and looks nice on my 2014.
blackbetty14
CT
Hemi 5.7 VVT/Etorque
The gap is not to prevent rubbing. It’s so the light can be adjusted. It can’t be angled up or down if it’s pushed up agains the bumper. This is why the fog light is designed on a pivot on the sides and a rear adjustment. It it was up against the bumper not only would it not adjust but then it wouldnt rub either unless there is a ton of play that allows movement.
But you are right, the light is oversized to prevent stuff from getting around it but I’m sure stuff still does as there is a gap and at speed air will just force he water around it.
mpress2570
If it did sit flush it would most definitely wear away. Every single piece of your truck moves, twists, or vibrates while hitting bumps. We will all one day experience the wear of that pivot point. There are videos out there that show fixes for it? But even that pivot point will wear over time and your housing will become loose inside its assembly. And it could go either or both ways. It could not sit flush for adjustment purposes or wear purposes or both. They could have made the light adjust from inside the housing instead of the whole housing itself. Like how the head lights adjust.
TMFMK
