My catalytic converter is very clogged! Can I use a cable bit to drill holes in?
Triple Black
Atlanta, GA
5.9L V8
My truck's cat is completely clogged. The truck won't rev over 2.5k rpm. The truck has no power what-so-ever. I need to drive the truck 100 miles on Saturday to work on it at my dad's shop.
As a test, I removed the upstream o2 sensor to confirm the cats are the problem. The engine revs like a ***** ape without the sensor in the hole, but it sounds down right awful. And I doubt it's even safe.
I never worked with a catalytic convertor before, so I have a question about how tough the honeycomb guts are.
I've come up with a plan is to remove the cat then drill holes with a 3/4" x 6 foot long drill bit entering from the right side exhaust inlet. The drill bit is used to drill into wood behind walls to runs cables. My drill does a great job with it when drilling into wood. I have no muffler as I cut the pipe behind the mid pipe hangers. Any loose bits will just disappear out the back.
Here's the bit:
Klein Tools 3/4 in. x 72 in. Flex Auger Bit-53751 - The Home Depot
TL;DR: Can I use an extra long bit to drill a few holes in the cat?
LB3711
Trumbull, CT
3.6L V6
yes but you will never pass emissions and its technically illegal. Plus you will throw codes.
Saseacasea
That would work as a quick fix, but hopefully you won't be visiting emissions testing as you will not pass. Just have them replaced.
dapepper9
Iowa/Nebraska Border
5.9L V8
It'll go through it no problem. That honeycomb can be busted into billions of tiny pieces with a piece of rebar.
Triple Black
Triple Black
Atlanta, GA
5.9L V8
The bit is a wood boring bit. You'll burn it up withing minutes trying to drill thru the platinum.
Thanks! I figure as much. I really didn't want to mess up a $40 drill bit. I instead drilled a 3/8 hole in the cat to relieve the pressure. It sounds like ass, but it will get me to Alabama.
sbarron
Wasilla, Alaska
Wait, what?!?! You're going TO Alabama?!?! ;)
Stegs
1998 Dodge Ram 1500 4x4
5.2L 318 C.I.
Here's the bit:
why dont you just buy a magnaflow high flow cat thats direct fit?
https://www.summitracing.com/search...atalytic-converters/make/dodge/model/ram-1500
TMFMK
