My iPad/ phone mount solution
carcandy
South Florida
2018 Big Horn cc 4x4
6.7 CTD
I was already invested in the Ram Mount system and wanted something that wasn’t intrusive when not in use. So I used the ram t slot rail in the upper cubby.
just mounted it with some screws( had to make one small hole in the radio bezel to clear the middle screw) if it loosens up over time I’ll use some small bolts.
I also trimmed the rubber mat so it looks as factory as possible.
TomB 1269
Schenectady NY
2019 Classic
Bayou Goat Mounts L.L.C. - http://www.bayougoatmounts.com/
Sells a mount that screws in the same
And for those wanting to play music from your phone without having a wire draped over:
https://www.amazon.com/gp/product/B07PDBBQK7/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
The last piece of my setup,
Wireless charging mount with auto clamping
https://www.amazon.com/gp/product/B07SCLNV9B/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
PS Bayou makes a double and triple mount plate as well.
PSS You will need to leave screws loose, then slide in modified rubber tray, and then lift each side to tighten mount, or at least I did, could not get rubber back in without doing so.
Narg
Tulsa, OK
5.7 eTorque
Unfortunately, that's illegal in most states. Good luck with not getting pulled over because of it. Great idea though.
KC Cryptkeeper
KCMO
2015 Ram1500
What is illegal I'm not sure I understand.
OC455
Central NY
He's probably referring to the mount and tablet partially obstructing the view....Most LE are not going to bother with something like that.
carcandy
carcandy
South Florida
6.7 CTD
Not worried about it, and it doesn't obstruct my view. I can still see the hood above it from where it sits.
carcandy
carcandy
South Florida
6.7 CTD
I did see that mount when looking around for ideas. I'm not really a fan of suction cup mounts. Also the T-track sits a lot lower in the tray so you don't really see it at all when not in use.
Razzman
Southern Arizona
2020 Limited CCSB
Neither am I and the reason I did this, magnetic arm. Easy to pop on and off
0dcbe7c8-2656-45f9-adfa-dd563fd6e905-jpeg.181441
MidTennMtneer
Princeton, WV
Pentastar
Try this on for size for blocking the view. This is stock in the new Explorer. Might as well have just stuck a mount in there themselves.
Puba08
Long Island
Here’s the mount I bought. No views blocked. Slides in and out.
landisl_2000
FL
Carcandy, where did you purchase this mount for your ipad in the sunglasses holder?
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
I love it. GREAT idea. I made one for my GPS but used the GPS mount to a plastic plate. I can remove the GPS but not the mount ! Love your set up. Thanks
carcandy
carcandy
South Florida
6.7 CTD
