My Truck, Silver Sophie
kg93
kg93
AZ
So the 4.56 conversion is on hold currently. I have to take care of the scrape and my frame and other damage caused by my towing company issue.
For the scrape im getting $912 from the ladies insurance so i am going to line x my rocker panels and side steps with that.
For the towing incident ill be fighting with the towing company to get the damage fixed...close to $1600 according to my body shop quote. Should be fun
probably be back on the gear swap in may when work picks up
kg93
kg93
AZ
there's a whole long thread about it but basically it was a bad month.
UCA went out, took to shop to replace with mevotechs. While at the shop an old lady scrapped the side of my truck down the two doors.
Within the next few days, brake line ends up melting...no brakes so i needed to get it towed, when it was coming off the flat bed the guy let the winch out too much and it snapped back pull my bumper out on one side, bending the frame, braking a headlight mount, and a fender flare.
Old lady's insurance is covering the scratch... about to start arguing with AAA to cover the damage from the tow company
derekp
Buda, Tx
1990 5.9 Cummins
Damn bro that's sucks. It's extra ****** when you aren't the one that did the damage on your truck. Good luck with it man. Hopefully they own up to it.
kg93
kg93
AZ
yeahhh sucks but whatever hopefully they cover it
kg93
kg93
AZ
just a quick update. Just got my truck back from the line x shop. Got my rockers done, bumpers and side steps are still being worked on.
jlpowell84
Looks great! If I had decided to go lifted route I was going to line x the same as well.
Hope it all works out, if it was his fault I dont even see the debate!
kg93
kg93
AZ
yeah the towing company is paying for my bumpers basically. they're giving me $1527 to stop further "controversy". They got caught lying to the adjuster but don't want to admit fault. Whatever ill take it.
kg93
kg93
AZ
So I have the bumpers done, rockers done, and the fender flares and my grill is getting done in line x currently.
I didn't make an appointment for my gears yet, but that might be because i just bought completely custom kings from filthy motorsports. Set me back quite a few pennies. Custom valves, springs, length, everything.Front coilovers and rear shocks
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Build is looking great! I'm sorry about all of the mishaps but hopefully, everything will go well moving forward!
Adam
kg93
kg93
AZ
Adam
yeah its looking good! not getting any cheaper though! hahaha
Just stumbled on some mopar oem blacked out projectors used for 285 and 325 on ebay so i said **** it and ordered them, i needed new ones anyway. I was going to buy a painted set from retro shop but this ended up being cheaper!
CLOUDL1GHT
Lone Star State
Cummins HO
this build is awesome! in for the gear swap because I have seriously been considering it with a 4 inch lift
derekp
Buda, Tx
1990 5.9 Cummins
thanks! I'm getting there!
Lookin good man. I got my roof rack on finally. Built it myself. Has lights, my jack, and a 35" spare. You can check it out if you want on my build thread under yours.
kg93
kg93
AZ
yeah i'm eventually going to get a custom expedition style rack made that you see on a lot of tacomas. Ill definitely check yours out
CLOUDL1GHT
Lone Star State
Cummins HO
do you have more pics of the rocker panels bed lined? I have a ton of rock chips and am thinking of going this route to match the black fender flares I put on
kg93
kg93
AZ
what would you like pics of? just different angles?
JBatSea
