N-Fab Epyx Steps vs. Westin HDX XTREME Nerf Bars
packer96
Wisconsin
hemi 5.7 w/e-torque
MADDOG
Living in a Firepit
I've had both brands and really like the NFab products.
One thing to consider...don't get any step bar that is painted. They chip very easily, the tops of the steps get scratched and the paint will start to peel. Get some that are powdercoated. All of my NFab units were powder coated and they wear really well.
I had to re-do a set of step bars that were painted. I had them coated with bed liner and that worked out well.
Good luck with your choice.
BOWERSFJ
Uniontown OH
If you live in Winter weather, N-Fab’s powdercoating sucks !!!! Mine didn’t last 2 Ohio Winters before the bubbled and peeled .... And I have factory flares, and I had to modify the mount plate to fit .... Never again
Nick@GotExhaust
Supporting Vendor
SC
We offer and stock both. Both options are similar in quality which is them both being good quality steps. I would pick the ones I like the looks and function of the most as neither one is really better than the other.
Let us know if we can help. Message me if you would like a quote.
CincyZach
Cincinnati
Mine didn’t last a year here in Ohio. I sent them back and they sent me a new set. So far they are holding up.
MADDOG
Living in a Firepit
That's odd to me that the coating broke down so quickly. Do they salt the roads there in Ohio?
I put almost 90K on the set that graced my 2007 MegaCan.
BOWERSFJ
Uniontown OH
There’s a salt mine right under Lake Erie .... They sling that **** around here like it’s free .... It keeps all the oil spray people in business
MADDOG
Living in a Firepit
Ahhh...that would explain it. I don't think I traveled salted roads with the MegaCan. It was chemical de-icer stuff used where I primarily drove.
mikeru
Super Moderator
Moderator Supporting Member
2020 Limited
Hemi 5.7L non-Etorque
I have the HDX Extreme, and they also don't hold up well to winter abuse. I'm seeing surface rust in some areas. I'll probably just sand them down and coat them both in bed liner.
ripvanhalen
Detroit
Hi Maddog, Those look great on the mega-cab. Looks like a pretty long section of the bar is unsupported between the rear wheel and the rear mounting bracket. How much flex is there when you step on the bed access step? Thanks.
Fatboy1989
