Name a mod you did that you ultimately regretted
shibby927
The Great State of Iowa
Magnaflow 14m. Should have spent a bit more to get something better.
Nothing wrong with mine. Get a lot of compliments on my Magnaflow. What don't you like about it? Just out of curiosity, everyone has their preferences.
Having personally listened to many of the different offerings out there for these Hemi trucks, I honestly felt like Carven and Magnaflow are the two best sounding.
averageguy
Belleville Mi
hemi
After a lot of been there, installed that over the years, I am better at picking accessories so I am happy with everything on this truck so far. I will say with any modification if the phrase " its just as good as _____ but cheaper" is the reasoning, its probably not as good, other wise, _____ would go out of business. You get what you pay for usually holds true more often. Also, quick fix easy things like spacers rather than a lift are usually either a failure or a band aid for the real issue, you want a lifted truck. Then you have to spend more time and money to get the result you want.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Subscribed...
2012Lamarie
Those ****** leveling kits. Busted both my ****** factory UCA's
Should've of listened to the guys on the forum, and installed shocks from the start.
How did you bust a UCA? How big was the leveling kit? I ask because I just put on a Rough Country 2.5" kit. I did a ton and I mean ton of research and no one said they had any problems with a UCA.
quietpeen
2021 TRX
Hellcat
The problems with uca's popping ball joints really started in 2013
charonblk07
Calgary, Ab
F1-A forged 349ci
Biggest regret was buying a forged 5.7L rotating assembly instead of spending the extra money and getting a full stroker kit; that ties in with the bad idea of going to the F-1A Procharger, more boost = more problems so a stroker kit wouldn't require such high boost levels to make more power.
DavidN
Central Florida
El cheapo aftermarket black & chrome door handles.
(Purchased off eBay for around 20$/25$ each).
Had two of them break off when pulling my drivers door open in a rush.
Now I changed to oem chrome door handles.
(At least I can call myself now an expert in changing door handles - lol)
I guess it's like always - you get what you pay for.
bcbouy
pitt meadows/100 mile house
2021 power wagon
hemi
not really a regret,but using neg offset wheels and 35 m/t's for winter tires are really making a mess on my truck.come spring i'm going to have to drop some ca$h and sort out both aftermarket sets and put new tpm's in the camper carry set and use the positive offset for winter.
bcbouy
2021 power wagon
hemi
there's a prime candidate for duplicolor custom spray wrap.
VicViper
Memphis, TN
Either slapping a Dodge badge on my 4th gen or...
Putting chrome 3rd gen hub covers on my 4th gen steelies...you decide.....LOL
Sent from my iPad using Tapatalk Pro
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Definitely the first one! I kinda like the second one...
xrsman
Ontario
3.0 Ecodiesel
Air suspension leveling links on my 2016. I snapped the first sensor while making the new links, and snapped a second at a gas station trying to put the stock links back on while hooked to a trailer. $240 in new sensors, $60 in links. Back to stock and staying that way.
Whoever at Ram decided plastic sensors and links for the suspension would be a good idea on a $60K truck should be punched in the nuts.
Sent from my SM-G930W8 using Tapatalk
TerraNewf
NL, Canada
I'm glad you mentioned that, my will stay stock. BTW, how did you get your signature so big? I love it.
kylecarver1985
I regret putting a leveling kit on my 2016 RAM just because someone told me that 33 inch tires would scrub without one. Now the 1300 I dropped on new tires looks ****** because they don't fill up the fender well. 8ee68b73d3cde7295fa5b50a57f77a2c.jpg
Sent from my XT1585 using Tapatalk
quietpeen
2021 TRX
Hellcat
sucks someone told you that being that the stock tires that come on those 20" wheels were 33" tires.
DRkNESS
South Jersey
^^^^. I feel your pain there as I know the tires im going with will look smaller on mine also. But I didn't want to have to do a ton of work to make 35" tires look at home.
kylecarver1985
Yeah well I'm new to this and never really thought about pulling a tape on the stock ones. Guess I know better now. In my mind, rough terrain tires had to be "bigger" than stock ones. Ya live and learn lol
kylecarver1985
My gas mileage dropped so much with just going to these I would really hate to see what it would go to if I put 35's on there lol
kylecarver1985
And I went up to a 12.5 wide which still may scrub without a leveling kit. I'm not sure. I just know that the tires look to small on the truck.
KwyjiboJonesJr
