Need a favor 2wd guys.
Limeybastard
Shady Hills, Rednecksville Boro, Florida.
Can you please look behind your front wheels and tell me if you see any grease residue around the back bearing area of the sheek similar to the pics.
Many thanks.
Sent from my SM-N910T using Tapatalk
Limeybastard
Limeybastard
I just looked, I have no build up of grease or any residue
Thanks. Both my fronts hubs were like this,cleaned it up a few hundred miles ago and checked for play but all seems okay. Hard to believe both hubs have the exact same issue. Must have occured from new as noticed it at 10k miles.
Originally I thought it was me applying too much anti sieze on the hub face when I changed out my rims 8 k miles ago.. But today I did a tire rotation noticed I hadn't even applied any anti seize lol.
Farmer Fran
Earth
2025 Limited Longhorn
SST H.O.
Now that is clean!
Limeybastard
Limeybastard
Can anyone else please check theirs?
I cleaned it up and after 2k miles there seems to be a little more grease coming out.
Checked for wheel play with wheel off the ground. Non present.
Sent from my LG-H901 using Tapatalk
THETANK
up jor *** mang
2015 R/T
nice job cleaning, none on mine but I am at 600 miles and it has never been out in the wet.
S
scotts2012ram
Guest
We have a 5500 at work that did that on one side then the bearing failed not long after
Arturo Rojas
