Need a lift!
X Justus X
Argyle Texas
PowerTech 3.7L V6
Ok, so I'm want a 4 or 6 inch LEVEL and LIFT! My truck is 2WD. Once I get a lift i'm going to most likely get some 35" Tires. But I need to know where I can get a 4 or 6 inch lift for a 2WD.
Thanks
X Justus X
X Justus X
Argyle Texas
PowerTech 3.7L V6
Will that level me out too? Because the front of my truck sits lower than the back.
TexasRammer
College Station, TX
Do you want 4" up front or 4" in the rear? In other words do you want a level and then 4" on top of that?
Oefootball_70
OLATHE
Go with Rough Country, by far the best lift for the money.
It is also the only lift that allows us 2wd guys to "grow" with it. You can add up to a 3 inch spacer with this one and go to 9 inch of lift.
I recommend the lift highly, I run it happily. And its cheaper than every other 6 inch 2WD lift out there.
ivan
South Texas: McAllen area.
Not for 4th generation right?
Oefootball_70
OLATHE
Not sure anything about the 4th Gens.
But from my understanding you can run any lift for a 4th gen and add the adjustable bilsteins 5100's for an additional 2.8inches of lift.
garner
Harker Heights, TX
Yes the kit will level you out. The CST website lists what it comes with as far as front and rear
Edit: 4" comes with 4" spindles in the front and 1" spacer for the rear. 7" comes with a 4" spindle and 3" spring if 4.7, 3" spacer if hemi and 4" rear spacer
CST is the only kit for the 4th gen 2wd. And adjustable bilsteins are only for 4wd
Silver Beast
2008 Dodge Ram 1500 4x4
if you buy a lift for your truck that is made for a 2wd truck it should level the truck out... at least it did back when i lifted my ranger a few years back
ramhunter9
P-Star Jeep Wrangler
If you are looking for a CST lift .. PM me .. I carry them for the 2wd at a great price
Kustomblack1
las vegas
2015 Ram 1500 hemi 4x4 crew
395hp
level, 7" CST LIFT W/3" REAR BLOCKS. AWESOME
[yt]O4DtygSzHJU[/yt]
