Need a little help
RMI22
Missouri
My buddy has 2 12" subs that are 2300 watts, 4 ohm, DVC, 1150 RMS. He needs an amp but what size? Heres what I have gathered online. Any help is appreciated.
Product Identifiers
Brand Boss
Model PHANTOM P126DVC
MPN P126DVC
UPC 791489113878
Key Features
Car Speaker Function Subwoofer
Size 12"
Type Non-Enclosed Subwoofer
Elements 1-Way
Powered Non-Powered
RMS Power 1150 W
Technical Features
Min Frequency Response 25 Hz
Max Frequency Response 2 kHz
Impedance 4 ohm (Duel Coil)
Sensitivity 96 dB
Peak Power Handling 2300 watt
Etroze86
Grand Forks ND
Well judging from what you have given for specs I'd get an amp that puts out 600w to each sub. Boss has never been known for quality so I would start with that and see if they hold up
Sent from my SM-G920V using Tapatalk
R
RMI22
Missouri
Ok, so he should get a 2 channel 1200 watt? any suggestion on brand?
BlkRamRt
SoCal
HEMI 5.7
How much money does he have to spend?
Etroze86
Grand Forks ND
Yeah 1150w rms and I mean true rms will ruin one of those. Budget would help us with amp to recommend but all in all I don't think he will be happy with those subs.
MikeG
Livonia La.
If he's on a budget look at the Rockford fosgate r750-1d. It's 1ohm stable and does around 900 rms
R
RMI22
Missouri
He says he dont really have a set budget on the amp, he just wants a good one.
What would you suggest over the subs he has?
DRkNESS
South Jersey
Well first I would suggest that he sells those subs. Secondly I don't like to assume so please share with us the year, make, and model of the vehicle that it will be installed in. :)
MikeG
Livonia La.
How much space depends on what subs. All brand preform different in different air space
MikeG
Livonia La.
I'd go for 2 sundown sa-12 d4 wired at 1ohm on a RF r1200-1d
R
RMI22
Missouri
Ok, I will pass it on to him. Thanks
Any other suggestions are welcome. I'll let him decide what he goes with.
Etroze86
Grand Forks ND
Or the sundown sd3 as they are shallow and still have great output in a small box. Good 1200w amp should cost 300+ bucks with a couple of diamonds in the rough out there like the ppi 1000.1.
MikeG
Livonia La.
RF r1200-1d for 240.00 all day. A little cheaper if you shop around
R
RMI22
Missouri
He said he found a r1200-1d for like 320, I dont know where he looked though.
