Need Advice !!
BlueEyez0729
Saskatchewan
V8 6.4 Hemi
I had a rad leak on the lower right side. Mechanic told me my rad was cracked and needed a new one. I bought a new rad heScreenshot_20260507_083509_Messages.jpg installed it ( he is trusted) but I still have minor coolant leaking in the same spot. What's going on? The video is from before the new rad.
Dean2
Near Edmonton
The video doesn't play. However, replaced rad, leak still there. Are you sure it was the rad in the first place? You paid good money for the fix, take it back to your trusted mechanic and get him to fix it right. Clearly he missed something.
B
BlueEyez0729
Saskatchewan
V8 6.4 Hemi
That is the plan. He will be checking it again. And yes, he said it was the rad
Dean2
Near Edmonton
It was very clear to me that the mechanic told you it was the rad, however the question remains, if you still have the same leak, then he might well have been wrong and the actual fix was a lot cheaper and easier. Or the rad may have been pooched and he just didn't tighten a hose right. You will never know now unless you closely examined the old rad and could see where it was leaking.
MOPAR TECH
deptford
radiators are common to leak also water pump will leak rec u doing a coolant pressure test and see where leak is or take back to person that did repair and tell him its still leaking and your not happy dont know where u live but i can check it out i have 14 years of experience in dodge/ram
His avatar says he's in Saskatchewan,probably a bit to far from you :Big Laugh:
B
BlueEyez0729
Saskatchewan
V8 6.4 Hemi
I live in saskatchewan Canada. I know it's not the water pump as I have 0 symptoms. Hes coming to look at it later.
