So this has got to be the most frustrating smog situation ive ever dealt with. I originally fail because timing off (26 when it supposed to be 16) and NO PPM was off. I get timing fixed, i see on the gun its at 16, so I go to a different smog shop and the timing is still coming up as off but all the ASM testing is good, obviously timing was corrected as the NO went down within range but this smog shop is telling me timing is now at 27. The new smog shop has a free retest but if they are saying timing is off today when its not, its probably going to be "off" to them tomorrow when i take it back in.
Im bringing my truck back to the shop tomorrow to re test timing but i know the timing is correct as i saw it. Assuming timing is correct when they check tomorrow what do you suggest I do about the smog shop situation? I've already paid $60 to 2 different smog shops....
