Need Help ASAP!!!
develand
Trying to put bils in the front and for the life of me I can not get the upper control arm loose from the knuckle. Tried penetrating spray and some other things. Any ideas? Or secrets.
D
develand
Been trying. Maybe even more lol
12sportmc
NC
Hit it with the penetrating oil and then grab one can-a-man (jk jk) and then whack it HARD right at the knuckle where the ball joint slips in. Don't be shy with the hammer I promise it'll come out
D
develand
It took a lot of doing.
But if at first you can't succeed, swap to the other side and do it first. That helped.
Halfchrome
2017 1500 bighorn sxt
get it? I had to hit the ball joint screw itself with a hammer to get mine to break loose swing from the bottom up and wallah. just make sure you swing with authority and it will come off within 5 or 6 swings tops if you use enough penetrating oil.
D
develand
Yup got it. smacked the side of the knuckle a lot. Then got pissed and went to the other side. Did the other side. Smacked it again, took a break then again and it came free lol.
MADDOG
Living in a Firepit
6.4L HEMI
Sounds like a hell of a lot of fun! LOL
