Lower control arm help
shenanigan
Oklahoma
5.7 L
Changing everything except the spindleon the front of my 2011 Ram.. I have been almost 4 hours now on trying to get lowermcontrol arm off. Everything else is off . I can not get the camber bolts to come out to save my life.. Anyone got any ideas? I've never had this problem before and I have tried e erything I can come up with
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
If you can't get them.out, they could be rusted.
Sawzall and cut them out, new bolts, that is if you have not tried heat first.
If heat doesn't work, not much else to do but cut.
I understand completely thst is probably what you did not want to hear
mikeru
Super Moderator
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
Moved to the 4th gen section.
shenanigan
shenanigan
Oklahoma
5.7 L
Th
Thanks DILLIGAF you guys nailed it. I had to cut em. Guess I'll get new bolts tomorrow. I've had enough for tonight. I appreciate it guys
Take your big wallet with you,if you're buying OEM bolts from the dealer,they'll pop your eyeballs open on cost :rolleyes:
crcraft
