Need Help Coolent Queation?
Adams2013
I Changed The T-Stat On My Truck Yeaterday To A
180 Degree I lost About A Gallon Of Coolent
So I Toped It Off With Preston
I Was Told That Was A Bad Idea
The Coolent It Needs Is OAT
NoBody Carrys It Besides Dodge Dealer
They Are Closed Untill Monday
What Should I Do Untill Then
My Only Car So Need To Fix
Dodge Told Me The Mixture Of Coolent Will Turn To Jelly
Over Time....Can Somebody Please Help
What Do I Do Untill Monday???
popcenator
Omaha, NE
Use Zerex G-O5. It's approved and pretty much the only alternative to the Mopar stuff.
on the move..
A
Adams2013
on the move..
Nobody Carries It
I Called Auto Zone
Napa And Walmart
Nobody Has It Only Dodge Dealer
popcenator
Omaha, NE
That's strange, my local NAPA had it at the counter front and center. Have you checked different locations? I also saw OReillys had it but I didn't bother with them.
on the move..
popcenator
Omaha, NE
I'm not a 100% but I believe it should be fine to use. I can't imagine they changed it much if at all since last year.
on the move..
audio1der
Airdrie, Alberta
Another vote for topping off with distilled water.
With temps as high as they are you'll be just fine with more water in the mix for a few days.
20hemi10
SC
5.7L HEMI
Water should be fine. The 2013's use a new OAT purple coolant which is not the same as previous year coolants which was HOAT coolant.
Raadz
