Rustige
2007 Ram 1500, quad cab, 270,000 miles:
I just changed rotors, pads, and calipers all around. I have bleed the brakes 6 or 7 times starting at the passenger rear and working toward the master cylinder. I have bleed the brakes with the key on, in the ignition, out of the ignition, and with the battery removed. The pedal is still going to the floor. This is the third time I have changed rotors and calipers and have never had this issue before. The pedal will build firmness after a few pumps and brake well then. I am at my whits end, it has been two days of bleeding brakes and not getting anywhere. Is this my master cylinder or brake booster? The system acts like there is air in it, and before I changed everything the pedal was firm and braking was really good. I did change the rotors and pads I normally use, I used:
Power Stop K2164 Front and Rear Z23 Evolution Brake Kit with Drilled/Slotted Rotors and Ceramic Brake Pads
I got these off amazon, and have never used these before. I got the calipers from Autozone, Duralast, which I have used before.
Please help!
Thanks,
Mark
Please help!
Thanks,
Mark
