Need help with DDM HID and RS projector harness
2010 Infantry Vet
Butler pennsylvania
Went to install my DDM tuning HID's and retro shop projector harness last night, and didnt have much luck. Anyone have pics of installing them?
1500ram12
5.9L Cummins
Can you post some picks of how you have/had them. Everything is pretty straight forward
2018 2500 6.4L
Dmopar74
You don't need the harness with the ddm hids
1500ram12
5.9L Cummins
Double check the low/high connection. It's possible that the pins on the adapter harness are bent or not seated properly.
2018 2500 6.4L
1500ram12
5.9L Cummins
It's not uncommon for the pins to bent just enough to not be seated
2018 2500 6.4L
smoothee
St. John's, NL
What happened to the other projector adapter harnesses you had?
Even though your quads worked fine check your factory connectors, I had to change all mine out due to corrosion (I'm in the salt belt too). I'd try seeing if they work without the Hids first, if you have the stock bulbs.
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
This is what I currently have hooked up. Suggestions please. Is green plug turn signals, is is black factory halogen plug turn signals?
1500ram12
5.9L Cummins
Looks like green is your high/low and black should be turn/park
2018 2500 6.4L
1500ram12
5.9L Cummins
2018 2500 6.4L
IRSmart
I drink and I know things
Westminster, MD
2018 Power Wagon
6.4L Hemi
2018 2500 6.4L
This is only true if you will be stashing the ballast inside the headlight housing btw. If not, that jumper is how the wire passes through the grommet.
1500ram12
5.9L Cummins
He's using oem projectors so he wouldn't need that connector
2018 2500 6.4L
1500ram12
5.9L Cummins
Ddm tuning plug only has two pins, factory has 3 pins.
You should have 2 connectors off of the retro shop adapters. One goes to the turn/park and the other goes to the high/low. The ddm connector goes to the low beam connector inside the headlights. So the plug you took off the bulb for the low beam plugs into the ddm kit
2018 2500 6.4L
IRSmart
Westminster, MD
2018 Power Wagon
6.4L Hemi
2018 2500 6.4L
Again, only if the ballast is being installed inside the projector housing itself. If being installed outside the headlight, that jumper will need to be used.
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
2018 2500 6.4L
Correct, so I have two plugs coming off retro shop projector adaptors. When I plug those two connectors into my factory projectors, I either have parking lights, or headlights. Both won't work (this is without hid kit hooked up).
I think the retro shop adaptors are bad.
1500ram12
5.9L Cummins
The section that has the resistors on it goes to the parking lights. If you haven't tried that yet do it
2018 2500 6.4L
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
I have power going to the plug, but like I said, its either low beam or running lights that work. Not both.
I'm gonna call retroshop tomorrow.
