Need help with trailer brake controller
Pinnegar12
California
Eco diesel
I ordered a knock off oem style brake controller installed it, flashed it using Alfa obd hooked the trailer up everything worked for about a minute and now it intermittently connects and says trailer brakes disconnected can anyone help me out please
I have a 2017 eco diesel
A friend of mine bought the same one and did all the same steps I did and his works perfectly
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Do you indeed have it connected to a trailer when it shows that? The truck wire harness connector under the rear of the bed has been known to corrode.
Your trailer wire connection at the truck may be sketchy. Wiring on the trailer could be bad. Ground between the truck and trailer is a common place to have problems. You did indicate you and your buddy did everything exactly the same with the same controllers.
I would say you have a bad controller. Not uncommon for the ChiCom knockoffs.
Otherwise it's pretty difficult to give an informative answer to a vague question.
^^^ exactly what he stated
Depending on the model year of the truck there is actually 3 different ITBMs used with the 2013 through the Classic DS body trucks.
P
Pinnegar12
California
Eco diesel
Yeah it’s definitely connected to the trailer trailer pulled fine behind behind my 2018 ford with no issues with the trailer brake controller on that truck I will check the wire harness underneath the truck when the sun comes out
P
Pinnegar12
California
Eco diesel
It’s a 2017 big horn if that changes anything
The correct Mopar ITBM kit number is: 82215040AC
As stated above, I would suspect more that it's a flakey aftermarket unit given the number of them that have been reported on this forum. Some people get lucky and are able to request a new aftermarket module where as others ended up going with the OEM one.
turkeybird56
Central Texas
OP, go get rid of the Chinese junk and get you an OEM ITBM installed and flashed to the truck BCM.
