MolonLabe78
Schenectady, NY
5.7l Hemi
I’ve been experiencing a “bogging” sensation anytime I slightly press on the accelerator. It doesn’t matter what speed I’m going (taking off or cruising on highway) and it doesn’t do it when I give it more throttle....and the truck idles fine.
To try and fix the problem I’ve:
Changed the air filter
Cleaned the throttle body
Changed all the plugs and coils
Changed the MAP sensor
Cleaned the intake manifold temp sensor.....
And nothing has helped, I don’t know what else I should be looking for ....like with the injectors or another fuel issue but since it only has an issue during low demand I didn’t think that could be it.
Any suggestions?
2008 Ram 1500 5.7l Hemi
123k miles
MBRP 3” cat back exhaust
SYKRAMMAN
Banned
Jersey shore
06 Mega
Maybe something with the drive by wire system? It definitely sounds electrical. But I could be wrong. Does it throw any codes? Get ahold of a scanner and preform some live data runs to see what all is going on with sensors and such. Have you cleaned or replaced the egr valve?
MADDOG
Living in a Firepit
6.4L HEMI
It could be a dirty EGR valve and/or a clogged PCV valve.
I'd replace both if that hasn't been done in a while given the miles on your truck.
RonJon '06
Southern Minnesota
^^ Agree on the EGR valve. Have you tried deativating the MDS by pressing the tow/haul button? Another thing to consider is that the opened up exhaust is good for high rpm performance but hurts your low end torque.
